StiffRing for Proton waja (More corner rigid and stabil)
holydevil
What is Stiff Ring ?
Improve Handling, Reduce Noise, Eliminate Vibration
Stiff Ring made of special formula aluminium which used in aircraft frame building. It used to correct the car body basic geometry by filling the gap between the sub frame bolts, sub frame and the car body bolt hole. Car engine, transmission, suspension and the body shelf are mounted on the sub frame. Thus, correcting the geometry setup with Stiff Ring, the car handling will be improved significantly.
All Stiff Ring is come with 1 year warranty 1-to-1 exchange.
** We are authorize dealer, you may check at www.stiffring.com
Call/whatsapp +6012 879 4422
Price for proton waja: RM250 per set.
Try it to believe it.
facebook.com/HDmotorsports
coinstar
Ada sapa dah try? Tengok mcm best aje
mende tu je 250...mahal gop
StiffRing for Proton waja (More corner rigid and stabil) Great-12
