LUBEGARD is the ONLY product of its kind Used, Endorsed, Designated & Approved by multiple Car Manufacturers/OEM’s!
Now - RM73 (Market Price - RM75)
Please call @ sms Raden 019-6000 252, COD at kl area/putrajaya or nearest.
http://www.lubegard.com/~/C-112/LUBEGARD+A...luid+Protectant
-For use with any required *ATF’s!
-Prevents overheating, reducing elevated operating temperatures up to 40°F
-Extends fluid life
-Eliminates transmission fluid foaming and oxidation
-Reduces wear throughout the transmission
-Eliminates clutch chatter and torque converter shudder
-Optimizes total transmission performance
-Softens and modifies harsh shifts making them quicker in duration
-Maintains proper ATF viscosity index in the torque Converter
-Provides for smoother shifting
-Eliminates objectionable noises during shifts
-Keeps valves and governors free and frees stuck valves in valve bodies
-Assists in eliminating warranty comebacks
-Raises the thermal and oxidative stability of the fluid
-Only protectant that increases the fluid’s ability to transfer heat
-Does not contain any harmful components such as zinc (ZDDP) ash, etc. like other
competing products
-Protects new seals and permanently restores older seals to a "like-new" condition,
without adverse side effects.
-Also for use in manuals that require ATF
*Except Ford Type F ATF and CVT applications.
9 out of 10 Transmissions Fail Due to Heat!
Did you Know... For every 10 degrees F of heat reduced, you double the life of the
transmission fluid. For every 20 degrees F of heat reduced, you double the life of the
transmission! LUBEGARD prevents overheating, reducing elevated operating temperatures up
to 40 degrees F!
LUBEGARD is the ONLY Product with 28% Less Acid
The 28% factor is one reason OEM’s choose LUBEGARD. The reason you should use LUBEGARD, is
the very same reason OEMS do: solid test results and over a billion miles of proven
performance!
Results with and without LUBEGARD
LUBEGARD ATF Protectant is patented and proven by the top independent third-party testing
facilities to reduce oxygen uptake (oxidation) by 30%, component wear by 50%, and reduce
pentane insolubles (sludge) by 60% when added to GM factory fill (reference for DEXRON
approval).
-Extends fluid life
competing products
to 40 degrees F!
performance!
approval).
